Hi
Error F2 in asko dishwashers indicate high water level.
This may happen due to plugged drain pump or due to faulty water inlet valve.
To resolve the issue remove the back plate and check the drain pump. Disconnect
the hoses from the drain pump and clear the lint from the hose and the pump
area. Lot of water would be there when you'll
remove the hose from the pump, be ready to collect it. Let it dry and now the
dishwasher will work perfectly now. Hope it helps...
Daniel
Hello &
Welcome to FixYa
F2 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
Hello &
Welcome to FixYa
F2 is a drain error in your Kenmore washer, if
the unit is unable to drain then after 4 minutes it will display sud and then
other questions.
Kevin
Hi
Thanks
for using FixYa. F2 error means Long Drain. If the drain time exceeds 8
minutes, the water valves are turned off and "F2" is flashed. Press
PAUSE/CANCEL twice to clear the display.
Please rate the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
