6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
https://printcopy.info > brand=Kyocera > code=7900
Kyocera FS4100DN · Code: 7900 · Description: Drum unit EEPROM error. No response is issued from the device in reading/writing for 5 ms or more and this problem is ...
Use the link below which will take you to the manufactures website and download the printers operations guide. On page 3-8 it tells you how to clean the printer.
if you want to remove the fuser
you should start with the sides panels there should be some screws on the back and on the bottom that hold the sides after that open the top cover and it will give you access to the fuser from the back.
I hope it will help you
