I think you need to verify that the lamps are bad since it is delicate works to remove, replace and solder the lamps wires and put them back together. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
This is where I get my lamps from: http://www.lcdparts.net
You need to check the fuse, transistors, caps, and solder joints on the power supply/inverter board.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%20E173FPb/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Replacement board: http://www.lcdrepair.us
