You can find out what year a Bobcat is by contacting a Bobcat representative. Firstly, locate the Bobcat serial number - usually in the owner's manual or inside the door - and then phone up Bobcat.
Once you provide the representative with the serial number, they will be able to tell you exactly what year and model the Bobcat is.
What year is a 743 Bobcat?
The 743 Bobcat model was produced in the years 1987-1991. If you are unsure what year a Bobcat is - or even what model or series it is - you can use the serial number to find out.
By simply phoning the Bobcat team and telling them the serial number, you will be able to find out the year of your Bobcat in no time.
What year is the Bobcat 753?
The 753 Bobcat is a skid steer model. If you have a Bobcat 753, it will have been manufactured between the years 1999 and 2003.
The serial number is TH61192242. What year was it made? The date code for the year of manufacture is the third character (1st number) in the serial number (6) of this dishwasher. The number six in your serial number indicates that this unit was manufactured in 2006 (or 1996 if it is an older model).Sept 9, 2008
and
What year was my Kenmore dryer made?
To determine the age of your appliance, use your serial number (not model number) to find date of manufacture. Our serial numbers begin with two letters followed by six numbers. The 2 letters at the beginning of the serial number tell you the month and year it was made.
How old is my dryer by serial number?
You can determine the age of your appliance by looking at the serial number on the nameplate. The first number indicates the year of manufacture, and the second and third digits indicate the production week. For example, 13500016: week 35 in 2001.
How can you tell how old a dryer is?
To find the age of your appliance, use your serial number, not the model number. There are two letters followed by six numbers in our serial numbers. The first two letters of the serial number tell you when it was made.
Ed,
Near as I can tell, it's a 1979. As of 1980, Johnson/Evinrude used two LETTERS at the end of the model number to designate the year. (See attached) Your model number ends in a number and letter (1A) which leads me to believe it's earlier than 1980. Prior to 1980, the last two numbers of the serial number were the year. That's how I surmised yours is a 1979, by the last two of the serial. G02651879
The serial number alone is not enough to determine the year unless you also include the maker and the model number. Even then it may not be possible, but without that information there is not enough criteria to figure it out.
For example, if the tractor was made by Sears then you probably could narrow down the year based upon the years of production of that particular model at Sears.
Sometimes the year is embedded in the serial number, but the algorithm for determining that is based upon the maker and the model...there is no universal serial number to model year conversion... And in some cases the serial number has nothing to do with the model year... It literally can be a randomized number that's ensured/verified to be unique... However in that case the company may have a database that they can look it up and tell you.
my recommendation is to call the company that manufactured it and give them the model number and the serial number and they will probably be able to tell you... If they can't, chances are there is no easy way to figure it out.
Go to the Troy Built web site, find the contact phone number, call them and tell them what you want to know. Give them the serial #, and they may want to know the model also. They should be able to tell you what year it was made. Hope this helps. I will Actually see if I can find out the info for you. I will be right back. Sara I just talked to troy built, this is not the serial # this is a model number if you can check again for the complete serial# I can get you the year your tiller was made.
From you manual: Two-stroke oil For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines. WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here: HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/ Enter the 3 digit model number (no XPs, Es, just the numbers) Serial number decode – useful when downloading IPLs and Manuals 06 1500198 06 = year produced – 2006 (single digit before 2000) 15 = week produced - March 00198 = 198th unit Husky produced that week
HTH
Lou
