SOURCE: motorcycle fault
Check for a blockage in the fuel tank vent.
Run with the fuel cap cracked open - if it runs fine, try and work out where the vent is blocked.
SOURCE: I have a 2003 BMW 325CI, when i go to start it, it
First thing to check is the fuel pressure, there is a scrader valve under the black fuel rail cover to the right of the valve cover, just pop off the small circle and take off the 10mm screw. Hook up a a fuel pressure guage, then turn the key to the start postion and check the guage. there should be about 3.5 bar of pressure (50psi). If it doesnt build up it could be the fuel pump of a clogged fuel filter. If all this is good, then it may be a bad mass air flow sensor.
SOURCE: with my bmw318i 1997.i have difficulty starting
look for bad grounds in the ignition circuit.the corrosion is creating a voltage drop,but time and heat decrease the resistance..
SOURCE: BMW R 1150 R surging
Bad choke or stuck butterfly valve in carb. Could also be in need of valve adjustment. The only other reason would be because the timing is off.
SOURCE: bmw 316 ti 1996 wont rev up theres fuel and spark but start it runs for 30 seconds then dies
check TDI crank sensor. It might be missing pulses due to some faulty plug or connection.
