Question about Uniden GMR-1558 / 2CK 2-Way Radio
One of my Uniden 1558-2ck phones will not transmit. It receives well but when I press the call button or talk the signals are not received by the other unit.Both are fully charged.
Anonymous
SOURCE:
dobhan
Servando Nadayag
  • 105 Answers
SOURCE: GMR1058 Problem
have you try to check the ptt switch,it might be the pin or the there is a corrossion in the switch....
Posted on Feb 22, 2008
eradiostore
eradiostore
  • 1655 Answers
SOURCE: Trouble transmitting & receiving on uhf.
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Posted on Jul 07, 2008
eradiostore
eradiostore
  • 1655 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
Anonymous
  • 89 Answers
SOURCE: Transmit/receive indicator doesnt turn off
Not familiar with this particular radio but it should have an eliminator code. Try setting an eliminator code on both radios, ( they must use the same code on each channel) if you want to talk between the two. If there is a "MON" ( montior ) button, try pressing and holding it in until you hear a confirmation beep.
Hope this helps you.
Posted on Feb 26, 2009
Anonymous
  • 320 Answers
SOURCE: Some bands OK some not. No transmit, no readout on some.
its the problem of the frequency range its getting blocked  at particular location.these can be solved by two options 1)first try changing the location of the unit from one corner to another corner.that should help to catch the frequency again if its getting blocked at particular location.this happens many times.but if changing the locan does not make any difference.then  2) get checked that the antenna of the unit is not catching the required frequency for the unit.so change the antenna also connect this external antenna  as mentioned 50 ω (it comes wioth SMA Connector) that helps in catchinf the frequency. you will get this at radio shack website. this will help. ----------------------------- also in the unit there is a component which controls the frequency called microprocessor if that goes weak the unit slowly slowly stops receving the accurate signals and only the noise comes.so the micro processor in located internally in the left side.its a green and black colour mini chip circuit board.many times opening the unit and removing and cleaning the microprocessor and refitting it solves the problem but this is 50 --- 50 chance. this all has to be checked what mentioned. thank you for using fixya.
Posted on Mar 31, 2009
When I press the speak button, It display's TX and the other radio displays RX
tx is the word for transmit and rx is for receive
if you press the talk button, the unit goes into transmit mode and is received in the receiver of the other unit/s
now that your statement has been clarified what was the question?
Feb 26, 2016 | Radio Communications
Dial tone sounds static and voice echos. How to fix?
Hi anonymous, ;)
You can try to reset the phone by disconecting the battery..
Rconnect and place it on the receiving unit to reconnect it to the network
Apr 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I link uniden pmr845-2ck together
There is no "linking" of these radios. they simply have the ability to have silent receivers until a digital or subaudible tone is received that turns the audio on allowing you to hear the transmitted signal, this allows you to set the radio to only hear the correct transmitted signal...
http://www.manualslib.com/manual/733780/Uniden-Pmr845-2ck.html?page=15#manual
Feb 19, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Every time I press the talk button the radios show low battery icon and I'm not able to transmit on either radio. How can I rectify this problem?
Are you SURE that your batteries are up to snuff? I.E. when they have a light current load on them they are ok but as soon as you try to increase that current load they die off quickly. With two-way radios, the actual current drain depends on whether you are transmitting or in standby (receive) mode. Transmitting requires significantly more current than standby mode. So, I would look at what kind of batteries you are using. If they are a good name brand alkaline, check to see if they measure close to 1.5 volts with a voltmeter or check them with a battery tester to ensure they are good. If they are ni-cad or ni-mh rechargeable batteries, make sure they are rated at least 1200 mah (milliamp hour). I use Sanyo eneloop rechargeable batteries. They last a long time for me. One other thing, make sure your battery compartment is clean and there is no corrosion on the contacts the batteries are placed into.
Hope this helps,
Jim
Sep 08, 2014 | Uniden Radio Communications
Cobra frs 132 talk button not woking
The first radio has the transmit code set improperly.
Dec 15, 2012 | Cobra Radio Communications
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
Transmit/receive indicator doesnt turn off on one of the handsets, so that it receives white noise for a period of time after someone talks. Does anyone please know how to turn it off? Thanks.
Feb 14, 2009 | Uniden GMR648-2CK (22 Channels) 2-Way...
Handset doesnt work
Do you have another phone (cell phone) you can use to make a test call to yourself? If you can answer a call and the Uniden transmits voice OK, then it is probably the speaker and may just be a bad solder connection. If the handset does not transmit or receive I seriously doubt you have a bad microphone AND a bad speaker, you'd be looking at something more serious.
Jul 25, 2007 | Uniden EXS 2080 Cordless Phone (EXS2080)
Uniden GMR-1558 / 2CK 2-Way Radio Logo
62 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
