1992 GMC Jimmy Logo
Anonymous Posted on Jun 10, 2011
I have a 1992 GMC Jimmy and I was pulling about a 2000 pound load and I went into a wet spot in a yard and was stuck and I had done a lot of spinning and finally got out after about 5 minutes of being stuck and all of a sudden my truck started to make a squeaking noise and i stopped driving it and that noise is now a squeaking and knocking noise... what could that possibly be?
  • Anonymous Jun 10, 2011
    The noise seems to be coming from my engine
Randy Ohler
Level 3:
  • GMC Master 14,585 Answers
  • Posted on Jun 10, 2011
Randy Ohler
GMC Master
Level 3:
Answers
14585
Questions
8
Helped
3939865
Points
39683
If this sqeaking noise is more like a screaching noise and you reved the engine pretty high trying to get out, then you spun a bearing.
  • 3 more comments
  • Randy Ohler Jun 10, 2011
    Yep , It's time for a rebuild or engine swap. The good thing is that these engines are plentiful. They put them in everything. You can probably pick one up for $300 to$400.
    thanks. i have one more question also.. i was planing on buying a 1995 v6 camaro and i want to know what would i have to go through to put a 1995 firebird v8 engine in it and would it be expensive
    Since this is alll computer controlled you would have to get the computer for the V8, also the entire wiring harness Inside and out. You might get the materials at a decent price, but the work and time to do it , is alot, I mean really alot. Look in to it before you buy. But there are short cuts that take the time away, but they cost alot of money. $1000.00+
    so what would be the best and cheapest way to put a v8 inside it
  • Randy Ohler Jun 11, 2011
    Your best bet is to get an older engine and transmission, late 70's early 80's. these don't have the computer control and your car will have most of the wiring to hook them up. There will be few modifications to do. With the 95 V8 you need the entire engine compartment harness and the ecm. If the ecm is in the cabin of the car, then you will need the entire harness from there also. the transmissions should work out .The wiring is going to be more than half the time it takes to get the car ready. you will need a good electrical schematic, probably for both engine sizes. This would be the cheapest route
A
Anonymous
Ruined the trans possibly
Though all parents taught you about automatic
transmission spinning
1helpful
I have a 1992 GMC jimmy the digital cluster went out how do I fix it
You remove the cluster and take it in to your local GM dealership. They will send it off and get it repaired. Usually takes a week to a week and a half.
When i start my 2000 jimmy the engine stays reved up to 6000rpm and does not go down it stays like that
idle air control stuck wide open. Air bypass the trottle plate by IAC system or you have a big vacuum leak (brake booster , intake ,hose vacuum,and so on
Hi, i have a 2000 gmc jimmy and whenever it rains
How old is the cap? Could the new one be bad? Also when it won't start do you see any sparks jumping from the coil or wires?
1helpful
WHAT ARE THE TORQUE SPECS FOR A CRUSH SLEEVE ON A 2000 GMC JIMMY
There is no spec for that. the sleeve must be compressed until you have the correct pinion bearing preload. The pinion must take 3-5 inch pounds of torque to spin it.
My wiper on my 2000 gmc jimmy went crazy. I cant
its part of combination switch need to remove steering column cover to get switch off
2answers
Can i drive my 1992 gmc jimmy without the front differentical? And if not where can i buy one for cheap?
Yes you can drive without front differential. Easy way to do so is just dissconnect your front cv axles. Just make sure you dont throw that car into 4 wheel drive.
3helpful
2answers
1994 Jimmy - Rear brakes are dominating after brake job
You need to bleed the whole system. Once this is done it should work better. Make sure you are not low on brake fluid. If the front brakes are disk brakes and the rear are drum breaks, the front really does most of the stopping, the back jjust keeps the car from spinning or swaying. But the main stopping power is in the front breaks. They need to be bled correctly, make sure brake fluid is up and make sure emergency break is not engaged. The emergency break uses a lever and cable to activate the rear brakes. The emergency breaks don't run off brake fluid...
please give good ratings, they are very important...
2helpful
High Voltage on my 1992 Jimmy
your regulator is stuck in the alternator so replace the alternator soon because this will cause electrical problems
2000 gmc jimmy stuck in 4lo
if you do not have auto 4x4 try resetting the 4x4 computer by pulling the courtesy lamp and the ATC fuse for 1 minute. then reinstall fuses then cycle key on and off 5 times. please rate this answer.
1helpful
2000 gmc 4 wheel drive
Look in your fuse box for the bcm fuse (body control module) and remove the fuse atleast for a mint and then start the vehicle, put it in neutral and disengage the 4L and you are done once it is disengaged turn the vehicle off and re-insta the fuse yo pulled out and you should have no problem.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
