SOURCE: ''device not found'' on motorola I465 when attempting
you have to turn on the discovery mode on the phone in the blue tooth settings....usually will last for like a minute or so then hit the search or pairing button on the head set.
SOURCE: I'm having a problem with
Try to reset the system and then try pairing it again.When you reset all paired device to the speaker will be wiped off.start paring the speaker with your Droid x
To reset :
press and hold both Reverse and Forward buttons at the same time until speaker system resets.
Thank You
SOURCE: is there a firmware update
I'm having that exact same issue, with my Samsung flip phone. Works perfectly for one call, but have to turn it off, and back on again to work again.
Just curious if you have a Samsung too?
I did try it with another non-Samsung phone, and it worked like a charm, without issue...so I have to assume it's my phone?
SOURCE: Need passcode for Motorola H371 Bluetooth device.
I lost my pass code for my Motorola H371 bluetooth, can yoy help
