Hi , How can I replace the outer screen on the nokia n 76 ? I've got the parts, but no instructions on how to replace it. How can i get the damaged screen out and fix the new one in ? Thanks Guys
Hi, Thanks for yor reply. I've been to 2 different mobile phone shops and they don't do it . Do you have an idea on do-it-yourself ? Thanks a millionHi, Thanks for yor reply. I've been to 2 different mobile phone shops and they don't do it . Do you have an idea on do-it-yourself ? Thanks a million
did you replace all the parts your self or did you rely on the mechanics advice and paid for what he said it needed . Unless you really flogged the car I suspect that there was something going on and many of the parts may have needed replacing. For instance struts have an insert and it is not necessary to replace the whole thing including springs .
Hi once if a phone gets wet, it is very much risk if we don't put off the battery immediately .Because,as and electronics device it is run by current,when it gets wet the different components(parts) with different current (+ve and -ve) are sort.So, when we put battery/charger the internal components easily fused....So, the first aid is to put off the battery and contact mobile repairing shop.It could not be tried easily.....Therefore, I advise you to do not put the battery again,unless you visit mobile repairing shop.If you are trying to power it on by yourself repeatedly without any knowledge,most of the components may damage more worse.Good luck.Thanks for visiting fixya
If all other applications are working fine, you can receive call, and others, just the blank screen, the problem with your phone is just flex problem, the flex
on the screen of your phone is weak or worn out, this is a common
problem among slide or flip phone.
What you need to do is to
replace the flex on the screen of your phone, you can get this done by
going to any local phone repairer within your vicinity to help get it
fix or replace.
Once the flex is replace, your phone display
problem is solve and the screen will start displaying.
Operation is simple, just using the thin plastic plying tool or some thin flat bit screw driver (be sure to operate carefully not to scratch the surface of your phone) to edge up the old screen, then stick this new replacement screen at the same spot. Adhesive/glue has been pre-applied at the back of the replacement screen.
I’m surprised that instead of getting a response to my question posted yesterday in your Forum I’m getting an offer to switch to your Premium Assistance Plan. Nevertheless, I partially solved the problem.I found out that I need just the small outer LCD for Nokia 6103. I already found it on eBay.
But the main question remains: I need instructions, manual or pictures how to replace a broken outer Mini Display for Nokia 6103.
I'm muziclady & I had three choices to choose for replacing the screen. The first was to purchase a new screen through Sony's parts dept. site
Secondly I found this this site that makes rear pro. screen antiglare screens: http://www.glarestopper.com/measure2.php
Also from this site, it has instructions for the removal of the screen to measure & re-install. [which is easy]. The actual screen size for the 61" is 58x30 inches, & it's referred as being a 61" Projection TV Screen Only [Lenticular Fresnel] .
My final choice was to Google for a screen replacement. I was fortunate to find a used one from an RCA television..It's the exact same size, etc.
hi, yes the same problem I think, my outer (mirror) screen got cracked lifting a wheelchair
