Posted on Jun 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
Jack McCann
Level 2:
Novelist:
  • Expert 117 Answers
  • Posted on Jun 10, 2011
Jack McCann
Expert
Level 2:
Novelist:
Answers
117
Questions
0
Helped
39676
Points
374
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1657
Points
Expanded a bit more...
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Anonymous
Level 3:
  • Master 961 Answers
Anonymous
Master
Level 3:
Answers
961
Questions
Helped
273633
Points
3003
Digital optical is one of the best but, it will only transfer sound, not video. Digital coax is the same. The best thing you can do, make and model numbers on your components would help, run all your inputs through TV if you can, either by HDMI, or component cables. Componenet cables don't do sound either but, you could use RCA for sound. If you feed to TV first, then feed audio to reciever, it should work. You will only have one audio output on reciever and can select your output through TV.
1helpful
Sharp Aquos 32D64U LCD HDTV. I need help connecting and/or setting up an Ematic AT103B digital converter box.
Question edited for clarity and order, 'make model (what it is)'.
On the television remote you have to select the Source or Input. Each press will take you through the HDMI ports and all other signal inputs like co-ax. Your LA channel is likely via the co-ax indoor aerial.
Support Details LC-32D64U
Sharp Electronics https://www.sharpusa.com > Support
Owners Manual. LC-32D64U ' LC-37D64U Operation Manual. DownloadOpens in a New Window. FAQs. These are FAQs related to your product. My TV is not powering on.
Sharp LC-32D64U 32" 16:9 AQUOS HD 1080p LCD ...
B & H Photo Video https://www.bhphotovideo.com > ... > Televisions
The LC-32D64U 32" 16:9 AQUOS HD 1080p LCD Television is an ultra-slim and light LCD TV, that easily enhances the decor of any media room.
I need Aquos LC-37D43U firmware
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
1helpful
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
No picture from cable box to tv
If you get on screen menues using the Sharp Remote then you have a main board that is defective. If you just bought it new you are in luck as the warrenty on that unit is a lease 1 year parts and 1 year labor. Contact Sharp Customer Service and should be able to refur a Sharp Auth. Repair facility to get you taken care of. In the mean time, If you got on screen menues then you can go to any one of the other video inputs and see if you get a picture.
If you DO NOT get onscreen menues with the Sharp remote then you are out of luck until a service repair facility looks at it.
Hope this helps,
Skyassoc
3helpful
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
2answers
Need some sound to my home theatre system
Just 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
 Grubhead
Grubhead
SmartAviator
SmartAviator
