SOURCE: Monitor keeps shutting down into power save mode?
This happens when the capacitors (680uf/25v & 1000uf/16v) on power supply board are blown.
Please locate an LG service center close to you by following this link
SOURCE: LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Testimonial: "Settings are not the problem. The problem is with monitor itself and it is not related to operating system."
SOURCE: i have an LG L1952HQ LCD monitor that shuts off
greatatuin1, Tell me the "date of manufacture" from rear of unit!! You may need to inspect the units power supply printed circuit board or black-brick switchmode power supply. Is power supply "lay on floor" type or internal to monitor case? Is your pc working ok with "differerent" monitor?? Have you been to youtube to watch "refurbishment" DIY videos of cold cathode-fluorescent-lamp back-lit lcd monitors??? If unit is really old and has lots and lots of "on" hours, you may even need to replace the CCFL lamps also. Tell me more info, so I can advise you. Symptom seems to be "black screen of death" !! Have you performed or even know the "flashlight test" that every ccfl lcd monitor owner should know??? Do additional comment back to me. 12fixlouie
Power saver modes on the monitor has several functions. First the power saver preserves the devices from consuming current while viewer is mometarily away. Screens that display power saver modes returns to regular viewer mode soon as the remote controls or buttons are manipulated slightly as indication of request to regualar views. The power saveer mode of the screen can be disabled. Obser ve the feature functions of the device iether on the remote controlof device buttons. Power savers perform simialr to screen savers or device feature manipulations. Access the devices settings or menu buttons to display the entire list to buttons for disactivation of power savers modes. Usually the power saver mode may be onsctruting viewer experiences for situation that momentary displays ate idleness requiring to retore to viwer display screen. Refer to the devices userguide to attain details.
