I have a problem of error on konica 7135
error code is:l detection - adjustment
Is it possible that I entered the numbers manually? Otherwise it will suggest the way?tanks
Re: I have a problem of error on konica 7135
error code...
Off the machine ,hold 2and 5 simultenously then on the copier press software switch then go the # 16-0-0 16-1-0 16-2-0 16-3-0 16-4-0 16-5-0 16-6-0 16-7-0
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Hello sir; The error code you display, it means fuser temperature too low, but it can be reset;
1, hold down 2 & 5 keys while you turn on power.
2, choice 1 for software switches.
3, use U/D arrow key to pick up dipswitch and bit number.
4, pick up dipswitch 3, bit 1 and change 1 to 0 by pressing "off"
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier. Press the P key, then enter 47, then press P again. Enter 0 and press the Print key. Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
