Make sure that the media you are using has the surround sound...eg. if you are listening to the radio then the rear speaskers will not work as the signal is not transmitted in surround...if you put a dvd in that has the dolby digital signal encoded on it then the rears should work....the rears will only work when you have the receiver in the surround mode..make sure the receiver is in the right mode...also, you may have rear speaker volume settings in the setup menu that may need to be set up..go through the manual and see if there is a setting for the rear volume...most home theater sets have this feature and it allows you to set up the system for different size rooms
