Somehow this is related to the SD card. I had replaced the original 2 GB SD card with 8 GB one and it was working fine. I used to use the flash as a torch by using the record function with flash and then pause which leaves the flash ON to be used as torchlight. But then it broke down displaying Camera failed. I did lots of troubleshooting but it didnt work, finally I inserted the original SD card back and the cam started working. Try this:Switch Cam Storage to SD card then remove the SD card from the cell and reboot the cell without the card. let the cell work for few mins(30 to 60mins)without the SD card. Now insert the SD card and reboot the cell. wait for few mins and check. Replacing the SD card from another cell may also work.Good luck
My samsung galaxy p1000 camera keeps failing when turn it on
