Kodak EasyShare M853 Digital Camera Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My camera is the Kodak Easy Share M853 ta give her lens error 10f, 1,0,0 helps me
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kodak Master 102,366 Answers
  • Posted on Oct 18, 2012
Kodak Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428598
Points
622693
5 Related Answers
A
Anonymous
  • Posted on May 12, 2008
SOURCE: Lens Error 111,0,0,23 on my Kodak Easy Share c743
have a look at this
http://www.josepino.com/other_projects/index.php?lens_error_kodak.jpc
A
Anonymous
  • Posted on Aug 10, 2008
SOURCE: Kodak Easy Share C330 lens error 14 and lens error 22
Hello, i just let my camera to a friend and when she return it to me it didint work because of the error 14, then i just changed the battery for a brand new ones.. and it start working..
hope i can help.
A
Anonymous
  • Posted on Oct 01, 2008
SOURCE: kodak easy share
the only thing that you can probably do i take it to somewhere where they can fix it. It is probably the only thing that will work. sorry. =/
Anonymous
  • 70 Answers
  • Posted on Mar 22, 2009
SOURCE: lens stuck
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Anonymous
  • 141 Answers
  • Posted on Apr 22, 2010
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
2helpful
2answers
Yesterday I was at the pool taking pictures of myself, my hands were not wet, then my camera just froze and now it won't turn on or off, it did say lens error: 101,1 ??? Is there a cheap way to repair...
hi, just go to service center and tell what is happen.error you got is only adjustment or the lens was stuck up maybe because of impact from the lens while you taking picture.cleaning and adjustment charges are cheap or sometimes they will give free of charge.
thank you
EasyShare M853 Digital Camera: I am trying to upload pictures I took last night f...
Use a card reader instead of the camera and download to a folder you create on your desktop.
My camera won't come back on
the lens array has been damaged dude..you had either dropped it down or put it in you bag in switched on condition which should have forced the lens to get inside(resulting in damage).
please take your cam to the nearest service center to get it done, since it needs a pro and specialized equipments to calibrate to normal once it is opened..
if its covered under warranty you wont be levied on service charges, else it costs around 60$
2answers
I have a kodak easy share m853 when I turniton auto lens error comes up on the screen and won't stay on.
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
2answers
Hello. I have a Kodak Easyshare M853 and everytime I turn my camera on it says "lens error error 10f,1,0,0" and then turns off. The lens is extended out and it will not retract. It has not been...
try to leave the batteries out for a day or two, it'll reset the camera, but it'll only last a week or two, then odds are, it'll do it again. I had one to do the same thing- and the camera was only 6 months old- i don't think it can be fixed without sending it off.
Nov 24, 2008 • Cameras
1helpful
2answers
KODAK LENS ERROR 122 1 0 0
if your looking where it says lens error 122 then when you turn it on it will say it i have the same problem but worse
2answers
M853 Kodac Camera
go to kodak and chat with a customer care rep.
he/she will guide you as to how you can troubleshoot the problem
2helpful
Lens Error Message 10f, 1, 0, 0
I just had the same problem like 10 or 5 minutes ago. I think that I am going to need to get a new one, take it to a lens(camera) shop, get a refund or take the damn thing back..and or, get a "NEW" thosand(jkjk) dollar camera..oh! and did u know that now! at walmart they are selling a deluxe package that comes with this same camera for $147.99..I was so mad when I seen and heard that because my mom bought this SAME camera for the SAME pice that they are selling the SAME camera w/(with) more things included...grr, damn you koday(jkjkjk lol) any wayz, I think that i am going to trade it in for that lol...thanks ya..peace!
8answers
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
