Hi, I would check the pump out. Air maybe getting in pump. You should get a rebuild kit for pump.
Gasket(s).need to be replaced. cracked or ripped. Hope that works for you.
I replaced the fuel pump when replacing all fuel line parts. This type of pump is disc driven run by air flow, common to many Riding Mowers in the JD, Huski families. They are self contained & not rebuildable in any event. Priming to the carb didn't help either so I will next try starting fluid to begin the prime cycle but doubtful. Thanks, though.
Thanks for replying; I would be careful using starting fluid. it can blow up the motor.
I have heard that this can happen.
Check for a weak spark in ignition system. Repace if nesscesary (crank sensor)
And when you have flywheel off replace ( key ). The key may be bent on shaft this could be why hard to start. Good luck.
Assuming you have fixed this by now, was it low oil level?
The problem is in the transition to Ethanol gas around 20045/6.. Pre 2005 fuel lines & gaskets deteriorate readily in alcohol fuel, particularly if left sitting. Same is true for all vehicles, pre 2005. Solution, replace all rubber fuel lines, gaskets & most likely, fuel pump with post 2005 lines & gaskets... anything deteriorateable exposed to ethanol fuel.
