you have some options, so choose one.
- remove your fax
- configure your fax to answer later (maybe after ringing 10 times) and configure the winfax to answer before (something like ringing 5 times or less)
the problem here is that the fax answer and start receiving the fax and the winfax receive the fax signal at same time. check the winfax maybe you have the half part that the fax modem not has printed stored in winfax, maybe.
as I said, your better choice is removing the fax modem. even configuring like I said before, maybe the two continue to try to receive the fax at same time.
hope it helps.
