From your cook top, there are 4 wires. BLACK, RED,GREEN and WHITE.Out of that GREEN is ground and WHITE is neutral.The BLACK and RED are positive and negative wires.-------------Connect it as follows:---
Black from cook top to black on house wire.--------
Red from cook top to white on house wire.( don't connect red or black from cook top to bare copper wire).
Now white from cook top to bare copper wire at house plug.
The green wire is your ground wire and it just connects to a screw going into the frame of the cooktop.
It should be grounded to the metal frame on cooktop.
You can also connect this way:---
cooktop black to the wall black, the cooktop red to the wall white , and the cooktop white and green to the wall bare.---
Join both green and white wire of cooktop together to its ends, then connect that to wall bare wire.--------
This will help.-----------Many uses face this problem for wire connection.So this combination connecting of wire helps.------
The other option is to change the wall receptacle, there are 4 wire receptacle available at home-depot and Walmart stores.It costs approx $15 for this 4 wire wall receptacle and any local electrician will get this connected for you, with his basic charge.-------
This will help.Thanks.Helpmech.
I have connected the wires as you suggested and everything seems to be working as it should. I appreciate your expertise in this matter.
This solution worked for me.
