Question about LG Dehumidifiers
Unit comes on for 3 seconds/ shuts off led displays 01 ???? reset keeps repeating
  • LG Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Jun 15, 2011
6ya staff
SOURCE:
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
Unit shuts off. CH 01 shows on display
heatman101
Jun 25, 2011 | Comfort-Aire BHD-651 Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Unit only runs a few seconds and then shuts off
If the water reservior is empty then the float is stuck in the full position.
May 26, 2010 | Comfort-Aire BHD-651 Dehumidifier
Bucket full light flashing but not full, humidity % shows as 01%
I posted an extended answer to this problem with part replacement info and pictorial. Why hasn't this solution been posted???
venasguy@comcast .net
Jan 28, 2010 | Kenmore 54501 Dehumidifier
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Jun 26, 2009 | Comfort-Aire BHD-501 Dehumidifier
01% humidity
When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
The compressor is located in the rear bottom on the right side looking at the machine. After you press the start button and the blower fan comes on, bend over near the back of the unit and listen for the "click".
Sep 06, 2008 | Kenmore 54501 Dehumidifier
Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
Jan 09, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
