Cell Phones Logo
Posted on Jun 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought an LG Prime gs390. It was advertised as unlocked. I put my Tmobile sim card on the phone and it works fine for text and voice calls, but I can't access the internet. I have been trying to change APN settings to ones provided by tmobile, but they're not working. I keep getting Gateway timeout messages. I'm hoping somebody can help me. Thanks in advance.
Anonymous
Level 2:
  • Expert 160 Answers
  • Posted on Jun 14, 2011
Anonymous
Expert
Level 2:
Answers
160
Questions
0
Helped
20919
Points
573
Just call your customer care center ask them to send the gprs settings to your mobile ,when you receive it ,save it as your default internet setting. it will work fine . tank you!!
rate if it was helpfull !!
Nokia 5800 xpressmusic. i just recived this new phone from a friend because he bought a new phone. i put my sim-card in it it asks me for my simcard code. it accepts the simcard code but than it says...
I'm assuming your both on the same network? If your both tmobile customers or AT&T it should work without problems.
If not. The phone needs to be unlocked. to be used with another sim card from a different company.
And to do that. Your friend can call his carrier he bought the phone from, request an unlock code, then unlock it that way, and you'll be able to use it just fine.
Only if your on either Tmobile or AT&T. No other sim cards will work.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
I have tmobile service and I have an unlocked LG Prime (gs390). Everything works great except for MMS and internet. Every time I try to use these features I get a "bad gateway" error message. ...
you might not be having the GPRS settings saved in your mobile. call and request your service provider for GPRS settings, they will send you the settings and you can save it..now you will not have any problem using the MMS and INTERNET .
Thanks for rating Good luck
Invalid sim
1. (easyer way) When I got my Blackberry, I had to put it in a couple of times for it to work.
2. Buy a new sim card.
If this does not work, then check to see if it is unlocked.
2answers
If you unlock an at&t LG Xenon GR500 can you use it with a tmobile sim card ?
You can, but you may have issues texting, using mms, and internet. T-Mo would have to change the settings on the phone to work with their network for that; they may not do that since it's an ATT phone. Phone calls would work fine though without any changes.
3helpful
2answers
Unlocked verizon blackberry world phone wont work with t-mobile
i believe i had had the same issue.
i unlocked an at&t phone and put in the sim card and it wouldnt work. i called tmobile and the representative told me that they have to register the sim card to their network or something.
so just call tmobile and tell them you got a new phone and want to register it so the sim will work in the unlocked phone.
Help iphone
i bought an iphone on ebay and put a tmobile card in it i can make calls but can not unlock to get my texts or on the internet
Unlock Cingular LG CU500 for Cellular One
The LG CU500 is a 3G phone I think. You may need to change your SIM CARD to 3G. I had a razor and my Sim didn't work with the LG CU320 I bought. Also unlocking a LG phone is a little more troublesome that other phones. I found a solution on the web. sorry I don't remember the website address, but it comes up in any google search. Hope this helps.
Good luck
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
