Dear chilos,
Just check whether Num lock key is on/Off.
Make it ON and try
Cheers
Check these things and reply me...
1) Does the indicator blink when you press the Num Lock Key?
2)Other keys (Enter, +, -,/ )etc on that area works or not?
3)Trouble shoot Keys by pressing ALT key ie, ALT+1 gives ?, ALT+2 gives ?, etc.
with numbers lock on i am able to type the symbols /*-etc with the number pad. but when it is on nothing shows. with number lock off the functions on the numbers are active ie pgup pgdn home. with the alt key nothing happens.
One more thing... you have to test this keyboard with other System.
If the same problem exists.
I think the problem is caused to the hardware (IC) related to digits on that area(number pad). So good solution is to buy a new keyboard. Buying a new one is better than servicing this.
i pressed the num lock key but the numbers still dont respond
