Sounds like malware or a virus is on the computer. I would google Malwarebyte and run it. Then Quarantine the Malware and restart the computer. It should stop the issues.
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
SOURCE: need driver A135-S4527 xp
just put toshiba A135 - S4527drivers in the google website u will get lot of links select one and download it
SOURCE: driver mass storage controller
go to support.toshiba.com click Ask IRIS type Intel Matrix Storage Manager and download the file , make sure its for the same chipset.
SOURCE: Touchpad problems - toshiba laptop and synaptics
hey
wat u tell is could be hardware problem in ur touch sensivity BUT still
1st go to control panel check the mouse setting and reset ur setting if everything is perfect thn change it like change the settings and then restore ur setting this is try to make it activate ur setting of ur touchpad
ALSO do try to go to device manager from control panel then select the setting of MICE & Other Pointing devices and selct the touchpad select it then right click on it and go for update driver option and update ur drivers from internet let it search it automatically and restart ur system .
if still not solved get it checked by engineer as it would be hardware prob may be some wire would be loose from inside ur laptop
