LG LS-L1210CL Mini Split Air Conditioner Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Displayed F8 error - LG LS-L1210CL Mini Split Air Conditioner
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Jun 15, 2011
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1158288
Points
10260
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7300
Points
Its the same for Westinghouse changing the sensor worked
Super General Washing Machine. E3 and F8 which error on the washing machine?
Question edited for clarity.
E3 is a generic 'Off Balance' code
If you receive an E3 Error code, your washer may be unbalanced. This could be caused by the washer being too tightly packed, or clothing not distributed evenly. This will usually occur during the spin cycle. Stop the spin cycle.
E3 - Error Code - Stacked Laundry Center - Whirlpool Canada
F8 is taking too long to fill. Check the filter screens on the rear hoses.
The F8 E1 or Lo FL error code means your washer is not detecting the correct amount of incoming water. If the washer has an F8 E1 error or LO FL error, the door may be locked, and the control may be unresponsive.
Aug 21, 2023
F8 E1 or LF or LO FL Error Code in Display - Washers - Amana
F8 display
sensor error , replace sensor by new one , problem get fixed,
2answers
Hotpoint ariston washing machine display F8
Go HERE to read about this error code for "all-in-one" models
2helpful
When am switch on the air condition displaying error f8
Code F8
Error detail Input circuit fault. Check indoor fan mechanism locked or no power to voltage. If no power to motor replace PCB. If power and still your motor locked replace motor. Is it helpful?
6helpful
2answers
F8 error
F8 on tamashi ac
Inspiron 1200 "Fatal Error" , cannot F8 into safe mode
Press "F8" while booting up. It should give you an option to go to safe mode.
2answers
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
