ASUS Eee PC 1000H Laptop Logo
Posted on Nov 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I wanted to install windows xp on an eee pc 1005ha h, and when the windows installer is loading the data( on that blue screen) I get in about 1 minute the error: "***STOP :oxoooooo7 (0xc0000005,0xf75de0bf,0xf7a2a208,0xf7A29F08) *** pci.sys - Adress F75DE0BF base at F75D7000, Datestamp 3b7d855c" What should i do?
Bill Boyd
Level 3:
Top Expert:
  • ASUS Master 53,816 Answers
  • Posted on Nov 09, 2017
Bill Boyd
ASUS Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949593
Points
172802
To start with win xp is no longer supported by Microsoft as is win 7
that means that any faults will not be rectified so if it doesn't install correctly after a couple of attempts up grade to win 8 or win 10
many programs will now not run on xp as they all modified to run win 7 or later
1 Related Answer
Anonymous
  • 2110 Answers
  • Posted on Feb 16, 2009
SOURCE: Blue Screen
Try disabling PCI-Express in BIOS setup
My asus PC1005HA will not re boot after I upgraded BIOS
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
Im trying to use skype with video capture but its saying it cannot find a video capture device. Its got a vide camera built in etc so how can I re install the software or settings to get it working?
Hi crewmsltd
Sorry to hear you are having problems. Please move all you data off your ASUS Eee PC 1005HA-PU1X-BK drive as we are going to wipe the whole drive. This means any data left on it will be deleted forever; irretrievably. You can do this with a thumb drive/USB stick. Please make sure all the data is moved. I cannot stress this enough. Once we wipe the drive it is gone forever.
Once you are totally happy all your data has been moved and you have checked this we can do the restore which takes just a few seconds if it is Linux or longer if it XP.
  • Start your Netbook and press the F9 key on your keyboard until you see a loading screen.
  • The restoration program prepares the files needed for the operation.
  • A message appears asking if you want to perform the operation, you will lose all files on your machine.
  • Confirm by clicking ?.
  • The restore process is done automatically , without any human intervention.
  • At the end of the restoration, the machine will reboot on its own, and make configurations.
  • A restart is performed again, and you're on the setup process of the Operating System , same as the first boot after buying the Netbook.
Then check for any updates. Read twice and click once and only install updates for 1005HA-PU1X-BK It may offer updates for other models and you do not want to install these. Install the updates one at a time and it does take some time. This fresh install should install the latest version of Skype which has support for using the webcam. Earlier versions did not.
NOTE: Please make sure you have moved all your data from the drive before doing the restore. All the best now, Phil
1helpful
Not able to reboot after windows update. My model i Asus eee 1005pc netbook. I dont want to loose the data that i have by taking reset to factory options. Any way out
how far do you get before your computer stops booting? I believe that this was only a coincident that it happened after a windows update. have you tried booting using the Windows "safe mode?" you can do this by pressing the F8 key during the boot.
in the future you should configure a second partition on your hard drive and save any and all data to this partition, this way you can reinstall windows and all of your data will be safe.
best to do this during the installation from Windows, but there are also tools out there that can do it after windows is installed.
hope I could help
How can i get Asus Eee PC back to factory settings?
Hi. Actually when you restore your system to its factory settings it will restore everything on your computer including the original operating system, but if you're saying that you have installed windows 7 on it then try going to ASUS driver support website, just type in their the model of your machine and it will ouput every software and drivers available for laptop and also different versions of operating system, So just choose the correct OS version for your laptop. Hope this Helps
1helpful
7answers
HOW DO U REBOOT AN ASUS EEE PC 900 WITH WINDOWS XP AND NO CD ROM
Hi! Please try this, restart your pc. During the start up press F9, it will restore it. Hope this helps and have a good one!
1helpful
2answers
A new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
2helpful
4answers
Asus Eee PC 1005HA - Windows won't Start
i have the exact same problem. those solutions cannot help me. i dont have any hardware installed or anything plugged into it besides the power cord. also it doesnt have a cd drive so i cant put that xp cd you were talking about. what else can we do to solve this problem. i cant get past that screen to do any of these solutions. please help
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
