SOURCE: Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. [email protected] if anyone can help.
SOURCE: VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
SOURCE: DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
SOURCE: DVD Player tray Door Continues to Open
I had this problem and it turned out to be the gears on the door drive. There are two gears, one that engages the rack on the tray and one that has a slot that drives the clamping action to hold the DVD. These two gears were misaligned by one tooth. This prevented the gear with the slot from turning freely after the door was closed.
To fix it I had to take out the tray assembly, disasemble it, and reassemble it with the gears properly aligned. You need to remove the top and back of the case. Then take out two screws at the rear of the tray assembly and three screws on the circuit board attached to the tray assembly. Unplug the connections to that board. Slide out the tray assembly. Now you can pop the top off of the tray assembly by pulling out two tabs and sliding the top toward the rear. Now you can get to the gears to adjust them. The slotted gear should be able to turn freely for about 1/4 turn when the tray is closed. Make sure the pin on the clamping part is in the slot when you reassemble it.
SOURCE: DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
