Every TV has different names for the menu selections but it will be in an area like "access" or in "set up" and then to a category like "language options" . On your remote you will press "menu" to get to the help screen. Next, scroll to whatever makes sense. Could be "display options" as well. If you can tell me what your menu selections are I can get you a lot closer but this should get you in the right direction. The most frustrating part is getting out of the menu. Either use 'exit" or use the key that has an arrowed circle for "return to previous screen".
Check ur tv original remote for a botton that said CC.Pushes this CC button a couples times to turn all functions like CC 1,2,3.. to all off.This will turn off all subtitle known as Closed Captionning.
