I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are
saved by default to the camera's internal memory, which holds different
amounts of images based on how many megapixels are built into the
internal memory and what image quality and compression are selected in
the camera's menu. Once a memory\picture card is inserted in the camera,
the camera then saves the photos to the memory\picture card and ignores
the internal memory.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
There are two ways to transfer the images from the internal memory.
Thanks for understanding. Please let me know if you require any additional help.
With a memory card in, press the Home button.
Press the right side of the function button to scroll through until you see the heading Memory.
Press the center button to select the icon.
Scroll down to Copy
Press center button to copy internal memory to your card.
It will show a loading screen.
When complete, check you card for successful transfer and then wipe internal memory.
There is no "back up" funktion" on kodak LS755, or I cant find it. thanks.
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Testimonial: "Exactly what i needed to know. Thanks!"
SOURCE: lost my usb cable
Your camera manual will tell if transfer from internal memory to card is possible.Some do some do not. Another USB cord should not be very expensive
SOURCE: How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
SOURCE: i dont know how to transfer photos from the built in memory to the memory card.
I had the same problem but found the previous solution skipped a few steps for those of us that need to be walked through these things! Here is what I did to transfer the photos I had on the internal memory on my Panasonic Lumiv camera:
Press Menu, use down arrow to move option on left side from "mode" down to "playback" (shows an arrow), then use right arrow to move to list and down arrow to scroll to last item on last page, which is "copy". Press menu to select it, then choose the first choice, which is internal memory to memory stick and push menu and you are done!
how do i do this on a Sony super steady shot dsc-w80? als known as "cyber-shot"
