Intex 1000 Gallon Swimming Pool Filter Water Pump () Logo
Anonymous Posted on Jun 16, 2011
Does the pump has to be on all the time? - Intex 1000 Gallon Swimming Pool Filter Water Pump ()
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
65
Points
Yes the pump should be on continuosly to keep the pool water filtered.
  • Anonymous Jul 10, 2011
    But the intruction manual insists that when persons are using the pool, the pump should be off. When you plug it back in, don't forget to reset the red circuit button on the plug.
1helpful
How to time a Ford 7500 turbo backhoe
Timing a Ford 7500 turbo backhoe involves adjusting the timing of the engine's fuel injection pump. Here are the general steps to time a Ford 7500 turbo backhoe:
  1. Locate the timing marks: Look for the timing marks on the engine's flywheel and the timing cover.
  2. Clean the timing marks: Clean the timing marks to ensure they are visible and easy to read.
  3. Rotate the engine: Rotate the engine in the direction of normal rotation until the timing mark on the flywheel lines up with the pointer on the timing cover. This indicates that the engine is at Top Dead Center (TDC) on cylinder number one.
  4. Remove the fuel injection pump: Remove the fuel injection pump from the engine.
  5. Adjust the timing: Rotate the fuel injection pump until the timing marks on the pump housing line up with the timing marks on the engine. The exact timing specifications may vary depending on the engine and fuel injection pump model.
  6. Reinstall the fuel injection pump: Reinstall the fuel injection pump and secure it in place.
  7. Verify the timing: Rotate the engine again to make sure the timing marks still align correctly.
  8. Test the engine: Start the engine and test it to ensure that it runs smoothly and efficiently.
It's important to follow the specific procedures and timing specifications provided in the engine's manual or by a qualified mechanic. If you're unsure about timing your Ford 7500 turbo backhoe, it's recommended to consult with a professional mechanic or technician.
Kubota injector pump PFR 3kx type, how do I set timing when reassembling
Setting the timing on a Kubota injector pump PFR 3kx type involves a complex and precise process. Here are the general steps to follow:
  1. Remove the injector pump from the engine.
  2. Locate the timing marks on the engine and the pump. The engine timing mark is typically on the crankshaft pulley, while the pump timing mark is usually on the pump body.
  3. Rotate the engine to the top dead center (TDC) position for the cylinder you are working on. This can be done by inserting a tool into the engine's timing hole and turning the crankshaft.
  4. Install the pump drive gear onto the pump shaft in the correct location. This may involve aligning the keyway on the shaft with the key on the gear.
  5. Align the pump timing mark with the engine timing mark. This ensures that the pump is timed correctly with the engine.
  6. Install the injector pump onto the engine and torque the mounting bolts to the specified torque value.
  7. Reconnect the fuel lines and any electrical connectors.
  8. Turn the engine over several times to ensure that the pump timing is correct.
  9. Check the engine's performance to ensure that it is running smoothly and efficiently.
It's important to consult the manufacturer's service manual for specific instructions and torque values, as the timing process can vary depending on the model and type of Kubota injector pump. If you are unsure about any step of the process, it's recommended to seek the help of a qualified technician.
2answers
Citroen Berlingo 1.9d. 2002. Fitted with DELPHI injector pump. Timing of cam belt & flywheel is by locking
I have been doing research on the Delphi pump and it apparently is associated with lucas/cav and as such is timed by the use of a dial test indicator that, through the use of a plunger and cam, runs on the cam block in the pump and determines when injection begins. Initial timing is to set the flywheel on the injection timing mark and the pump flange mark set on the timing case mark. To get it exact I would recommend that you have a diesel pump shop do the timing using the correct tools. As the pump is not electronic as such (from my research into Delphi ) it is basically a manual injector with a electronic controlled governor. Any way the best advice is to have a pump expert set the timing.
1helpful
When my fuel pump didn't turn on, my truck wouldn't start, if it did turn on it started right up. I replaced the fuel pump and it starts every time, but the fuel pump doesn't turn on every time. Is...
the fuel pump don't turn on every time . first when the pump as prime or if system is prime the pump will not turn on
the PCM give a ground to fuel pump relay for 2 sec and while the engine is cranking the pump is running all the time.
but pcm don't prime each time
Water pump
All three of these engines a timing belt driven which means the water pump is also timing belt driven. The water pump is located behind the timing belt covers on the front of all three engines. The timing belt has to be removed in order to service the water pump. Yes coolant can leak out the pump when it is bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2helpful
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
4helpful
3answers
Do you have to change the water pump when changing the timing belt/timing?
You don't have too, but not bad idea, the timing belt drives the water pump, if you just replace timing belt, and not water pump, water pump could go out and mess up the timing belt, now it has to be done all over again, timing belt, water pump and labor.
Change oil pump from engine
THE 3.0 ENGINE YOU HAVE TO REMOVE THE UPPER INTAKE MANIFOLD .REMOVE VALVE COVERS REMOVE ACESSORY DRIVE BELT.REMOVE THE POWER STEERING PUMP.REMOVE ALTERNATOR REMOVE WATER PUMP .REMOVE AC COMPRESSOR AND BRACKET .REMOVE CRANKSHAFT PULLEY REMOVE OIL PAN REMOVE OIL PUMP SCREEN AND THE TUBE REMOVE FRONT COVER REMOVE TIMING CHAINS REMOVE CRANKSHAFT TIMING GEARS REMOVE OIL PUMP.WHEN INSTALLING NEW OIL PUMP AND OIL PUMP SCREEN AND TUBE TORQUE BOTH 89 INCH POUNDS. THE 3.9 ENGINE REMOVE THE CRANKSHAFT PULLEY REMOVE FRONT COVER REMOVE THE PRIMARY TIMING CHAINS REMOVE OIL PUMP MOUNTING BOLTS REMOVE OIL PUMP.INSTALLING NEW OIL PUMP TORQUE BOLTS TO 53 INCH POUNDS. WARNING YOU NEED A REPAIR MANUAL IN ORDER TO RELINE TIMING MARKS ON CAMSHAFTS AND CRANKSHAFT.
1helpful
How do I change a water pump on a 2004 kia sorento?
Kia Sorento 2003-05
Water Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Disconnect the negative battery cable.
  4. Remove the drive belt and the water pump pulley.
  5. Remove the timing belt cover, timing belt, auto tensioner and idler pulley.
  6. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  7. Remove the water pump mounting bolts.
  8. Remove the water pump.
    Fig. Water pump and timing belt assembly-exploded view
To install:
Fig. Water pump bolt locations
  1. Clean the gasket surfaces of the water pump body and the cylinder block.
  2. Install the new water pump gasket and pump assembly. Tighten the bolts to 12-16 ft. lbs. (17-22 Nm).
  3. Install the water pump fitting, the thermostat case and the water outlet fitting.
  4. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  5. Install the drive belt, water pump pulley and then adjust the auto tensioner.
  6. Refill the coolant.
  7. Run the engine and check for leaks.
  1. Before servicing the vehicle, refer to the Precautions Section.
To install:
Fig. Water pump O-ring installation
  6. To adjust the drive belt tension, hang the belt on the pulley of the tensioner and install the tensioner.
    NOTE If the tensioner is already installed, loosen its mounting bolts to allow belt installation
  7. Install the drive belt.
  8. Adjust the belt tension to specification by turning the adjusting bolt clockwise or counterclockwise.
  9. Air conditioning belt tension should be 0.28-0.039 inch. Alternator belt tension should be 0.39-0.051 inch. Power steering belt tension should be 0.31-0.051 inch.
  10. Torque the tensioner assembly bolt to 33-36 ft. lbs. (45-50 Nm).
  11. Refill the coolant.
  12. Run the engine and check for leaks.
TY for using Fixya; remember comment and rated this.
4helpful
2answers
2004 chrysler 300m 3.5L waterpump location and does it run off the timing belt/chain
Yes the water pump does run of the timing belt system.
Directly from the service manual:
The 3.5L water pump has a die cast aluminum
housing and a plastic swept vane impeller. It bolts
directly to the right rear timing belt cover using an
O-ring for sealing. The water pump is
driven by the engine timing belt.
REMOVAL
The water pump on all models can be replaced
without discharging the air conditioning system.
WARNING: DO NOT REMOVE PRESSURE CAP
WITH THE SYSTEM HOT AND UNDER PRESSURE
BECAUSE SERIOUS BURNS FROM COOLANT CAN
OCCUR.
NOTE: It is normal for the water pump to weep a
small amount of coolant from the weep hole (black
stain on water pump body). Do not replace the
water pump if this condition exists. Replace the
water pump if a heavy deposit or a steady flow of
engine coolant is evident on water pump body from
the weep hole (shaft seal failure). Be sure to perform
a thorough analysis before replacing water
pump.
(1) Drain cooling system (Refer to 7 - COOLING -
STANDARD PROCEDURE).
(2) Remove accessory drive belts (Refer to 7 -
COOLING/ACCESSORY DRIVE/DRIVE BELTS -
REMOVAL).
NOTE: The water pump is driven by the timing belt.
(3) Remove engine timing belt (Refer to 9 -
ENGINE/VALVE TIMING/TIMING BELT AND
SPROCKETS - REMOVAL).
(4) Remove water pump mounting bolts (Fig. 31).
Note position of longer bolt for proper re-installation.
(5) Remove water pump body from engine
Here is link to get a factory service manual relatively cheap.
2004 Chrysler 300M Service Manual Covers every serviceable part.
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
