Maytag MED5600TQ Electric Dryer Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum goes around but no heat clothes do not get
Drum goes around but no heat clothes do not get dry The slip says MED5700TQ
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Jun 19, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10833168
Points
101584
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Taking 2 to 3 hours to dry a load of clothes...checked dryer vent from dryer to outside and it is not clogged.. what can the problem be?
Are the clothes hot when you take them out? If not, then maybe your heating element is broken. Easy to replace that, just pick one up from a parts store.
Our dryer started to take a long time to dry clothes but the heating element was working. We opened it up to check for lint and so on, and it turned out that the drum had slipped slightly out of location and the back of the dryer was partially obstructing the duct. That was probably what was making the dryer squeak, too. We reseated the drum easily in a few seconds and now it dries well again.
Feb 18, 2011 • Dryers
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 • Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
1helpful
2answers
I have a estate electric dryer with no heat.
check the heater coil and limit switches....if either are bad you wont get any heat
2answers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Fisher Paykel Elec. Dryer
Usually the belt is a single piece that wraps around the entire drum. The fact that you smelled something and that you feel the clothes are not being tossed tells me that the belt was slipping on the pulley of the motor that drives the drum. This will heat up the belt causing the smell. If the belt gets too loose, this will happen. I'd replace the belt, and I think you'll be back in action.
Let me know what happens. Please rate accordingly.
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
