SOURCE: Zebra Z4000 Stationery alignment.
Unfortunately, the guide under the ribbon spindle is the only real solution to this problem. I have the manual, but it's practically useless, and wouldn't have been able to help you regardless of how well it was put together. Try glueing a plastic or metal piece on the guide to make it taller, and make sure the guide is flipped up to keep the labels in.
SOURCE: We presently have a Zebra 110XiIII Plus Printer
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
SOURCE: Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
