There is only one gasket, Jenny. To figure ouut which way it goes, first put it onto the carby, then transfer it to the motor. Next put on the carby, and tighten the screws. Then hook up the electrical wiring and the fuel lines, and the job's done.
There is only one gasket, Jenny. To make sure which way the gasket goes, place it against the carby first, so you can see that the holes on the gasket line up with the holes in the carby. Then put it against the motor, followed by the carby, tighten the bolts, hook up the wire from the stop/go switch, connect any fuel lines that came off, and the job's done
