No signal I have LG Flatron 775FT 17" CRT and there is NO SIGNAL box on the center of my screen while the cable of Monitor is connect to graphic card and the power is off but when I turn on the PC, everything is OK. I check the graphic card it works correctly with other monitors. please help me how I can repair this monitor?
You can check the VGA Cable (the cable which connects the Monitor to Cabinet) try pushing the cable to the Cabinet. Check the same monitor to different system if Problem could be internal hardware - show it to computer technician
You need to check the monitor cable if it is correctly connected to the motherboard port. If the analog display or no signal it means the monitor cable should bot connected. If you have a video card in your motherboard you can plug your monitor cable to the external video card.
There's an internal hardware problem in your monitor, possibly cold soldered or defective electronic part/s. please bring the unit to an authorized service center for proper diagnosis & repair of the unit. best regards
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Doesn't look very good :(
You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty.
But all in all it looks like a fault from the monitor :(
Good Luck!
hi
your mail was failed so I upload software driver for LG775FT .
http://www.savefile.com/files/1792014
