Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds. Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle. Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01". Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00". Open the door and hold the "ON/OFF" toggle.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
