LG WM2455 Front Load Washer Logo
Posted on Jun 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer is showing dE message what is this mean?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1072
Points
De error? Clean pipe that was full of sand, clean the rubber gasket. Everything very clean but washer still will not run. Hear two click sounds then DE shows up! Help 5 kids tons of wash still
Anonymous
Level 2:
  • Expert 223 Answers
  • Posted on Jun 17, 2011
Anonymous
Expert
Level 2:
Answers
223
Questions
0
Helped
79716
Points
748
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
My LG Washer/Dryer shows error code dE
De error mean door is open. Check the door switch. You found in the link below how to reset the maschine http://www.lg.com/us/support/product-help/CT10000010-1400508168566-de
2answers
I have a LG front loader washer (WM2277H) that is showing a dE error code each time I try to start the washer. I checked to make sure that the door was clear. Any ideas on how to fix this?
Hello!
Please try unplug it in the wall outlet and wait for a while and then plugin ans switch on the washer. if not work then try to refer to the manual how to reset the setting of the washer.
melnavz
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
What do we when we replaced the pump on a frontload washer, LG, but still get an error message OE?
The DE Code indicates a Drain Error. This means that the washer thinks the water has not drained out of the tub within 10 minutes, which is an eternity for the washer. Since you have indicated that there is no obstruction in the hoses, and filter, and you have replaced the pump, then the only other parts that could be at fault would be the water level sensor, or the main circuit board. Replace in that order.
2answers
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
5answers
What does dE message mean on an LG washer?
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG - http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
Thanks!!
1helpful
After putting washing in the machine and setting the controls the machine fills up with water but thats all.On the display it shows the letters- de-.I would appreciate your assistance in this matter.Thank...
hello de error means this is a door lock error most of the time you would have to replace the door lock assembly this is on both lg and samsung washers if your model is another kind please message me back the make and model number and I will look further into the situation with your appliance also please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Error message dE
HELLO,
WHAT THIS SIMPLY MEANS IS THAT THE DOOR OF THE WASHER IS NOT PROPERLY CLOSE OR LOCK.
WHAT YOU ARE TO DO TO FIX UP THIS PROBLEM IS, FIRST OF ALL PUT OFF THE WASHER FROM POWER SUPPLY THEN PUT IT ON AGAIN AFTER SOME TIME, THEN OPEN THE DOOR OF THE WASHER AND CLOSE IT BACK AND / THEN MAKE SURE THAT THE DOOR IS PROPERLY CLOSE OR LOCK.
GOOD LOCK AND THANKS FOR USING FIXYA.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
