Question about Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera
Need driver PC lumix dmc zx1 - Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera
  • kakima Jun 17, 2011
    Have you considered NOT using a driver? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa (http://picasa.google.com ).
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Having gone over a month without a resposen to my query, I assume my suggestion to use a card reader eliminated the need for a camera driver.
Posted on Aug 14, 2011
6ya staff
SOURCE:
I tried to edit an image on sd card in Panasonic DMC-ZX1 via PC. Now camera will not recognise any card and will record only to internal memory. Card works in PC. What are my options?
First, back up any important stuff to the PC. Then format the card in the camera.
In the future, avoid doing stuff on the card. Copy the image to the PC, edit it there, then copy it back to the card. Be aware that any edited photos may not be visible on the camera.
Nov 21, 2016 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Have a panasonic dmc-zx1 in japanese and want to change language to english. I need baby steps
Go into the set-up menu (it has a wrench icon) and the next to last entry (it has an icon of a "face" trying to talk). One of the entries in that line will be "english".
Sep 09, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
I have a LumixDMC-ZR1 and need to download the software. I have misplaced my disc John Bolton
Hi Depends on which PC software you have! If you just plug into your usb port, PC will find drivers for you! No need for disc! If not you can download off internet! just type in camera name & model \ software - drivers etc on search engine! Hope this helps!
Jun 03, 2011 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Lumix DMC-ZR1 / DMC-ZX1 Digital Camera: My lumix dmc-zx1 got wet with normal sweet water t...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to take out all moisture trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
May 17, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital Camera Logo
125 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
