LG LSC26905TT Side by Side Refrigerator Logo
Posted on Apr 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 25 side by side m# lsc26905tt Ice maker not making ice: Changed out master water filter for frig Depressed, held and released reset button on ice tray dispensing mechanism. Turned off and on the ice maker power switch. Currently there is ice in the tray, but ice maker has not dumped the load, so to speak. No frozen water in water dispensing tube, when I look into the tube I see darkness at the end of the tube, kind of like I am feeling right now, LOL. As red green would say, if the women don't find you handsome they will sure find you handy..... Please help
richie46
Level 3:
Top Expert:
  • LG Master 12,962 Answers
  • Posted on Apr 23, 2017
richie46
LG Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946057
Points
58151
Check to see if the ice tray heater is working. It melts the ice a tad so the fingers can push the newly formed ice into the hopper.
2 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 21, 2009
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
christian nielsen
  • 358 Answers
  • Posted on Apr 10, 2009
SOURCE: LG Fridge-Tube where water dispenses in ice tray is frozen solid
I think that the solenoid valve that supplies water to the ice maker is leaking ,it is located in the back of the refrigerator where you see a copper pipe or plasticpipe thatfeeds water to the refrigerator. Shut the water off and the power and take it out and replace it .
How do I fix ghe lglsc 36905tt blinking light problem on ice maker.
if an LG easiest thing is try defrosting... also sounds like the water filter is due to be replaced.
My ice machine not making ice
Is there ice in the ice maker? If there is frozen ice in the ice maker, ice maker is probably faultily.
Ice Maker Repair
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
I am having a problem with the ice maker on my LG. We changed the filter in the last week and now it will not make ice. It was workking fine before this. We have tried everything, HELP!!!!!!
Maybe the filter is not installed correctly. Take it out and re-install it. I suppose the water valve is on. Of course, the fact that the ice maker is not working may be just coincidence. Put some water in the ice maker, wait some hours and see if it will push the ice out. If it does, that tells you that the ice maker does work. Let me know if you need more help.
Since changing filter have no water in door and no ice
usually there is a reset button on the fridge that needs to be pushed.you may also try and unplug the unit for a few minutes
1helpful
Do all ice maker refrigerators have filters on the water line
Most refrigerators dont have one, Usually you can install on in the supply line. If there was on it might be behind the frig
1helpful
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
1helpful
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
