This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Hello &
Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
