Question about Tally 6312 Matrix Printer
Showing Ribbon Fault - Tally 6312 Matrix Printer
  • sawraj Nov 28, 2011
    i change the printer catridge but the problem is still ribbon fault
    President:
  • 261 Answers
Hi
clean the ribbon then if still same error chang the ribbon
Posted on Nov 13, 2011
    New Friend:
    Problem Solver:
  • 5 Answers
First replace ribbon then
clean ribbon sensor at left side
if not check cable to motor of ribbon works properly
Posted on Dec 28, 2013
Anonymous
SOURCE:
Printer ribbom
Maybe the printer ribbon didn't install properly.
Or
Ribbon Base Unit in fault
Oct 14, 2014 | Panasonic KX-P2023 Matrix Printer
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
O.comF1 code won't go off. Can't use my oven. What can I do?
Hi kellyhubble,
The F1 error code shows a defective membrane. To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Magic Chef Kitchen Ranges
My 13-year old daughter has a pentax optio ls1000 and the display screen is just showing pictures in shades of green. is this a fault or some strange 'mode'?
This is a fault in the LCD itself, and is caused by a problem in the LCD itself or the ribbon attatched to it. Try taking the camera apart and reattatching the ribbon, if this doesn't help, a new lcd is order, which can be purchased from amazon for usually around $20.
May 05, 2011 | Cameras
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
My printer is showing eror 11
Error 11 means ribbon feed error. Please check ribbon feed motor, ribbon feed driver motor and main board to locate the fault.
Jan 01, 2011 | Epson DFX-9000 Dot Matrix Printer
What is the problem with the oven when it shows codes E6 F2
Hi and welcome to FixYa, I am Kelly
The error & fault code "E6 F2" is a keypad or keypad connector problem. However... the control board can also cause this fault. Sometimes you can clean the ribbon and connector at the control board attachment point and correct this.
There is a tech sheet inside the control panel (envelope) that has all of the error codes listed.
The control boad has a female connector with 2 release tabs for the ribbon. YOU MUST unlock the release tabs to remove the ribbon. This is a tedious process but if your gentle and take your time you can coax the ribbon out of the connector. The contact area of the ribbon is quite thin. I have found that you can place something non metalic and FLAT behind the ribbon and then use a tissue to gently clean the ribbon wiping in the same direction of the electrical runs on the ribbon. I.e. wipe from above the bitter end down to the bitter end. (one direction only) The female connector on the control board is much more forgiving. Once you complete the cleaning process press the ribbon back into the female connector and lock the 2 tabs.
If this does not correct the problem you can end up changing the control board (1st) and the touch pad (2nd) to fix it.
If you need help with locating parts just respond here and I will gladly assist you.
Thanks for choosing FixYa,
Kelly
Nov 21, 2010 | Whirlpool RBD305PD Electric Double Oven
Washing machine showing fault code F.03 could you tell me the fault and how to cure it. thank you rob.
may be there's a loose connection to the main board , very simple to fix just pop the top off ( be sure to unplug your machine before you start) and reseat the ribbon connctor to the main board, also reseat a ribbon connection in the bottom of the machine ...........so if your machine shows f 03 give the above a go, good luck.
Sep 25, 2009 | Washing Machines
Fault code c-31:22
your needs repair in mechanism..Fault given is undetected reel motor rotation .This can be caused by a bad captan motor ,pinch roller bad or bad LS chassis ribbon from upper cassette mechanism.If unit has old type (B) mechanism ,there is a good change LS chassis ribbon is bad .When cassette is inserted and pushed into mech .The latch for LS chassis wears down ribbon and causing a sensor fault ..
Dec 05, 2007 | Sony Handycam CCD-TRV208E Camcorder
Microwave
Having the brand and model will help us point you to the parts supplier so you can buy a new keypad.
Please post back.
Oct 23, 2007 | Microwave Ovens
Tally 6312 Matrix Printer Logo
356 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Zaid Anarwala
Zaid Anarwala
CheckitRight
CheckitRight
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
