I will give you some of the check list.If you check this properly means you are problem will be solved.
*Has the drain hose been put flat on the floor?
*Is the drain hose clogged with lint?
*Is the drain hose kinked?
*Is any part of the drain hose higher than 20 cms from the floor level?
*Is The extension drain hose longer than 3 m
*Is a narrow drain hose being used?
