If you're using an adaptor other than the original zoom, make sure it's 300mA or more and try switching the polarity.
explain about the switching the polarity..is adapter has polarity?? o.O
Yes, if you have a generic adaptor instead of the original it should either have a polarity switch marked + / - or on a multi-adaptor you may change the polarity by unplugging the DC pin and reversing it (again there should be +/- markings). Getting these the wrong way around will stop your pedal from working.
If you do have the original adaptor this does not apply.
The Manual clearly states that the center pin of the adaptor is minus and the outer sleeve is the positive. Also, it is wise to use a good quality, preferably regulated, 9V adapter. Some cheap adapters are marked 9V DC but can give as much as 15V!
