My 20" B/W tv screen has lost the picture about 3 inches from the top and 3 inches from the bottom, its just black space now,how to troubleshoot these problem.
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
This sounds like your vertical section is malfunctioning. This can be caused by the vertical drive section which connects to the yoke transformers of your CRTs. I would suggest taking the set to a qualified repair shop and having them check the vertical section of the TV.
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
