SOURCE: quinny zapp bar keeps dropping
It sounds like you put too much weight on the back of the buggy - handles at some point.
This happened mine too. it clcks into place but it doent stay up.
I looked intogetting it repaired but it cost too much - in myopinion
SOURCE: problem with zapp seat
There are two blackclips on the top inside handles pull these gently to loosen the seat cover. Then repeat on the bottom. You will also have to unbutton the back of the seat (there are two black straps) then half fold the buggy and pull the seat towards you. Its a bit niggly and frustrating but does eventually come off.
SOURCE: Quinny Zapp Undeployable Frame
You have hopefully sorted this out by now, but I had a similar problem with my Quinny Zapp. I sprayed the button with WD40 (between the button and the surrounding plastic) and this did the trick for mine.
Best wishes
Nerys
SOURCE: hi, quinny zapp
Here is the US distributor of parts for all Quinny Strollers...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
SOURCE: the bar in between the handle bars has snapped can
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Hi saxokim, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What country are you in?
