This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
