Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
SOURCE: no sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
SOURCE: XMD3 unable to select anything but satellite
i have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
SOURCE: Clarion XMD3 Condensate Problem
the only way to remove moisture is to get it looked at by a local repair shop .Or remove radio yourself ..let it dry for a few days and see if it helped .Water in LCD may not dry completely and may rust LCD with in time
