Hi If the vent is clean and thermal fuse located at the back
inside the unit on the blower wheel housing tests continuity then error code 3
E means door circuit failure and the door switch lock assembly should be
replaced. Before replacing you can check for any loose or open wire terminal in
the door circuit. Hope this helps...please post back for further assistance. Daniel
