SOURCE: Error Message SC 570... Need to
Hello there, the Ricoh Aficio 3224C automatically resets itself after a specified time after each use. The settings for this can be turned off or On. If you are having problems getting the unit to reset itself then it is most likely as a result of the setting not being setup. Here is a link to the complete user guide to help you set the system reset back on. The procedure for resetting can be found in chapter 4 while chapter 6 has a trouble shooting guide which can be helpful.
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001027/0001027276/VB1567500A/B1567500A.pdf
Hope this support has been helpful? If you need further help do please request.
Thank you for visiting FixYa.
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
