This will be based on the 501 model as you did not give a model Also I am assuming speakers are 8 ohms which I have no firm information for the Tannoy, but they should be marked when you open the unit. We are allowed 40 watt RMS for the woofer and 20 watts RMS according to the specs. They do not tell us what impedance the speakers are so we will do calculations based on 8 ohm speakers... if yours are different, then recalculate; P = I^2 * R so for 40 watts and 8 ohms then I squared = 5 or the current is about 2.3 amps max... You COULD use a 2.5 amp fuse, but if they were my speakers I would use a 2 amp fast blow which gives a bit of margin for the woofer. Now for the Tweeter we have I squared is 20/8 so this comes out I squared equals 2.5 or taking the square root we have 1.58... you could use a 1.75 amp, but if they were mine, I would use either a 1.5 amp or even a 1 amp as the tweeters seem to get blown in these. ALL of these calcs are based on the specs of power for the 501 model and ASSUME 8 ohm speakers... Recalculate if your units have different impedance thaan the assumed 8 ohms.
