Question about Maytag MSD2756G Side by Side Refrigerator
Water is leaking onto the floor. There is ice buildup on the bottom of the freezer section.
    Master:
  • 385 Answers
You have an auto defrost drain problem.Look carefully in the freezer in the very back and bottom and that is where the ice is plugging up the line.You may also be able to get at the problem from the rear of the refrig.Hope this helps.
Posted on Jun 22, 2011
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Thanks for your help. I will see if I can find the back panel with the screws. If not, it sounds like a repairman is my best option.
Posted on Feb 06, 2017
Anonymous
SOURCE:
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Water gathers in bottom of freezer and thaws out and runs on floor. model LRFC25750TT
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | LG LRFC-21755ST Bottom Freezer...
Ice Buildup in Bottom of Freezer
Hi: The tube in the back of the freezer is not clogged with ice. It is most likely clogged with mold below the freezer section just above the warm tray where the defrost water evaporates. Also a pea or other piece of debris could have gotten in there. Do your thawing again and pour some clorox water through it and use a pipe cleaner if it's a tough clog. I hope this helps, Jeff
Jun 01, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
414 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Pierre Laplante
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
