SOURCE: pc connected to tv, image is fine, audio won't come out of tv
Had this same problem with my A215-S7416. Check the sound settings in the control panel. You most likely have a Realtek HD sound card, but have Microsoft drivers installed. The Microsoft drivers also provides a default selection for either the speakers or headphones. The Realtek driver only displays setting for the speakers. Go to the Toshiba support website, enter your model and check to see if there are Realtek HD sound card drivers. If so, download and install. That's how I solved the same problem you have with my machine. Good luck.
SOURCE: how do i connect my pc to my toshiba 42X3030D TV?
In the user manual it says what resolutions are supported. I think you have to adjust your resolution on your PC to match one of those listed.
SOURCE: connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
First try installing the latest ATI video driver, to make sure the HDMI output is fully supported.
Did you set your TV to select the HDMI input? nothing shows?
SOURCE: I have connected my pc
Hello apostolos,
If you are using the powersave (monitor off) feature, the video signal to the TV is switched off and it may not be picking this up again automatically. This can also happen if you switch the TV off. In either of these situations, you should be able to switch the TV display for the PC on again by holding down the FN key on your PC keyboard and pressing F5 once.
This key combination is standard on most PCs for switching an external monitor on and off but on some PCs it may also be F4. If neither of these are correct, look for an icon of a monitor on one of the function keys on the top row of yourkeyboard - or use the "Display Settings" or "Monitors" Control Panel (depending on OS) for switching external monitors on and off.
You may need to press F5 a couple of times while still holding down FN key to get the monitor configuration you require, e.g. PC monitor off and TV on, or both on.
If you are using an animated screensaver, the TV should not be losing the signal from the PC, but this can still happen if the TV is switched to standby or off.
If you can't get the TV to pick up the signal from the PC using the FN + F5/F4 combination, it might be a good idea to reset the TV to factory defaults and run the TV setup again.
Hope this helps. If you need any further assistance with this problem or instructions on re-setting your TV to factory defaults, please reply to me from within this page.
Regards,
BElectric
