Fisher Paykel EcoSmart GWL15 Logo
Posted on Jun 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On brand new machine the water pressure is ok (not great as we on low pressure) to back of machine but just dribbling out into tub... Model F&P MW612WH 6.5kg
James Foster
Level 2:
Novelist:
  • Expert 251 Answers
  • Posted on Jun 24, 2011
James Foster
Expert
Level 2:
Novelist:
Answers
251
Questions
0
Helped
132148
Points
474
Hi - these machines wioll require sufficient pressure to operate - but low pressure to a certain degree should be fine - takes longer to fill..
Suggest you double check the hoses to the right valve hot/cold etc - usually there is a filter on the hose and one on the inlet valve, hopefully its not blocked.
I cannot see any other component that would be faulty - as you say its brand new...
What is the lowest water pressure and flow for a admiral washer model #atw4676bq1?
When the water pressure is low, the water flow is just less.
When the diverter opens, it lets whatever water is there pass through, So there just has to be enough pressure to lift the water from the water input past the top of the tub to where it sprays out,
I grew up in a house with its own water system. When the water pressure was low, it just took longer to fill the tub. As the pressure dropped the flow became less and less, Even at a dribble water continued to flow until the water level switch turned it off.
Water continues to leak from water outlet into tub
-Tight more. If no solve the problem then replace with new seal.
Good luck
Mai
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
2answers
Hi the cold water just dribbles into the tub. if I
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
3helpful
2answers
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
2helpful
Washing machine leeks and doesnt complete cycle
When the washing machine starts leaking water all over the floor, you face a tough choice. Either call a service technician to fix the problem or purchase a new machine. Both decisions are expensive. Most service technicians charge $50 to $100 just to walk in the door and diagnose the problem, and labor expenses can quickly accumulate. After receiving the final bill, you may even wish you’d replaced the machine!
TIP: Make sure the water on the floor isn’t the result of a plugged floor drain. It happens!
There are two types of washing machines: belt drive and direct drive.
If you open up the cabinet and don’t find any belts, then you’ve got a direct-drive machine. Repairs are similar for both machines, but generally easier on the direct-drive unit.
The following photos are from a belt-drive washing machine. If you have a direct drive, refer to your owner’s manual or diagrams (see “Buying Parts") for brand-specific details.
First, Replace Leaky Supply Hoses
The first step is to locate the source of the leak. Empty the washing machine, move it away from the wall and start the fill cycle. Look for drips around the water supply hose connection at the back of the machine while it fills with water. Shut off the water and replace any old, heavily corroded or rusted hoses with new ones. If the hoses are in good shape, replace the internal washers only. Special no-burst hoses ($10), regular hoses ($6) and new hose washers ($2 per 10-pack) are available at home centers and hardware stores.
Turn off the water main or shutoff valve and unscrew the supply hoses from the back of the machine with an adjustable pliers. Pry out the old hose washers with a flat-blade screwdriver. Install new gaskets in both hoses and reconnect the supply lines.
Second, Replace Leaky Internal Hoses
If the supply hoses aren’t leaking, open the cabinet and inspect the internal components. Belt-drive machines typically have a rear access panel that unscrews. Access direct-drive machines by removing the two screws on the outside of the control panel and flipping up the lid. Then pry up the cabinet clips and pull off the entire cabinet. With the cabinet open, restart the fill cycle to check for internal leaks. Look for additional clues like rust and calcium deposits. Most often you’ll find the leaks in the spots we show inFigure A.
Hoses tend to leak around a worn-out spring clamp. First try to remove the spring clamp with an adjustable pliers. If you can’t get it, you’ll need a special $15 hose clamp pliers available from your local parts supplier. Replace the old spring clamp with a new worm-drive clamp. If the hose itself is cracked and leaking, remove it and take it to the appliance parts supplier for a replacement.
CAUTION: Unplug the machine before performing any repairs.
Washing machine parts are available at appliance parts distributors. (Look in the Yellow Pages under “Appliance Parts.”) Try to find a parts supplier with a well-informed staff, ideally ex–repair technicians, who can provide diagrams and help diagnose any problems specific to your brand of machine. A great Internet source is www.searspartsdirect.com. Enter your model number to access exploded-view diagrams and a thorough parts list for easy on-line ordering.
You’ll need the brand and model number for proper part identification. Model numbers are usually stamped on a small metal plate located under the tub lid or on the side or back of the machine. Copy down all the plate information and take it along to the parts distributor.
Third, Replace a Leaky Pump
Fourth, Replace Worn-Out Tub Fittings
The most challenging repair is fixing a leaking tub fitting, whether it’s the air dome seal ($5), the center post gasket ($8) or the tub seals ($15 to $20). Before proceeding, make sure that telltale drips are coming from around the tub. The details of this repair vary by brand and model. The details we show are for most Whirlpool and Kenmore belt drives. Study a schematic drawing or consult a parts specialist if your machine is different from what we show.
You’ll need a special $15 spanner wrench to remove the tub and replace the tub fittings on this type of machine. It’s available at your local appliance parts supplier. You can open the top of many machines by releasing the spring catches. However, on others you have to unscrew several screws and lift off the entire cabinet. Look in your owner’s manual or at a parts diagram. (See the manufacturer’s Web site or one of the sites listed in “Buying Parts.”) You’ll have to unscrew the water inlet and the tub snubber before unclipping the ring. Fastening systems for these vary by brand, as do attachment methods for the agitator and inner tub.
There are four tub seals that secure the outer tub to the cabinet, each consisting of a bolt with a rubber and metal washer. Rust often develops around one of the tub seals, causing a tub leak. A new tub seal kit will come with four new bolts and oversized rubber and metal washers that will seal small leaks. But if the tub is completely rusted through around the bolt, it’s time to buy a new washing machine. Replace all four tub seals.
If the leaking occurs only when the machine is agitating, a bad center post gasket (“doughnut”) is the culprit. Remove the outer tub to replace the center post gasket. While you’re at it, replace the air dome seal as well. Reassemble the washing machine and run a test cycle.
Thank you Sir, Have a nice day.
Water filling while door is open
if water is constanty dribbling into the machine then there is a leaking water valve on the machine, if not leaking in all the time then exessive water pressure at some time, dont thing it is the control
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
